manfy wrote:
you just need to adjust the idle current for the amplifier
Solid at 24mV
manfy wrote:
unlikely that there is something wrong with the input wiring, particularly since the left channel is working.
Nothing is wrong with the input wiring providing you plug in a Beogram on its original cord kinda proving my theory right.
To recap a bit - I have a 5 pin din to 2 RCA adapter cable, it works fine on both channels on QI and Tape with the following audio sources Ipod, Pioneer CD player and my Pioneer TT (but of course very softly on the TT which has no preamp)
If I use the same cable with the Pioneer TT (MM cartridge BTW) on QII the right channel is dead. Not intermittent. Dead.
You may recall from an earlier post that I recently acquired some other B&O toys, one of which was a Beogram 1001 with a busted stylus. So in the process of reading up a bit on the Beogram and looking at the circuit diagram I realized that B&O bridged left and right channel negative with the earth wire in the cable. The socket on the Beogram supports this, all the pins are bridged except left and right positive.
After a fluke chat with my vinyl guy I got put onto another guy who knew a guy who had a Beogram he wanted to get rid of. Turns out it was also a Beogram 1001 and I got it with a close to perfect SP14 stylus for +- 50 Euro. The rest of this TT looks like it got driven over by a truck, whole baseplate is shattered etc but now I have a parts machine.
So this afternoon I plugged my new SP14 into my nice Beogram 1001, plugged it into QII on the Beomaster 1000 and both channels worked perfectly. Listening to opera at 45rpm - not so nice - but very entertaining.
Thank you however for the above advice because I think I will need it shortly for my Beomaster 1001. There the one phono channel is intermittent. Its either the phono hi/lo gain switch next to the input socket or the phono selector switch, fiddling with either will make it work for a while but then the one channel just cuts out. Early days yet, haven't even figured out how to open that one.
Now I need to really beef up on the Beogram, figure out how to get into it, free up the fine speed adjustment which is seized solid and probably replace the belt so that Pavarotti does not sound like a duck on acid in a helium tank.
Best regards
Anton
