AntonvZ wrote:
BC154 on diode check , circuit off and unplugged Iām sometimes getting OL and sometimes 0.001V between emitter and collector. There is resistance of 4.3 0hm. At 0.001V does this mean the transistor is shot or is this just from being in circuit?
Hmm...I can't guarantee that the transistor is shot, but it's sufficiently strange to investigate further.
The 4.3 Ohm between C and E is way too low. In-circuit test can show strange values because of secondary circuit paths, e.g. when measuring C-E in diode check, you'll slowly charge up the 3000uF capacitor, which results in unstable measurement and as soon as you reverse the test probes you might see odd values caused by this voltage from the cap. Also, when you're connecting the red probe to the collector of BC154 and the black lead to the emitter, you should actually read 1.2 to 1.5V because you're effectively measuring the B-C path on BC141 in series with the zener diode in forward direction.
Anyway, we know for sure that something is wrong in the power supply and BC154 is currently your best bet. Here's what I would do now:
1) Unsolder BC154 and do a full diode test (in forward and reverse direction)
2) Now with BC154 removed, we have a good chance to get more consistent values in an in-circuit test of the remaining components:
2.0) First I'd double-check visually the proper connection of BC141 and 2N3055 (since you replaced those previously and it's just too easy to mix up B-C-E when you're in a hurry)
2.1) Measure BC154 C-E path on the PCB. If you still get low Ohm values, there might be a solder blob or something that short-circuits that path
2.2) Do a diode check on the zener diode. You should read 0.6V in forward direction and OL in reverse.
2.3) Do a full diode check on BC 141 again
2.4) If there are odd measurements on BC141, I might even unsolder the wires to the 2N3055 and recheck the BC141. At the same time I'd diode check the 2N3055
3) If all these checks are good and show no sign of component damage, I'd simply assume that BC154 is damaged in some way. The diode test on transistors is very rudimentary and does not guarantee that a transistor is good! In 10-20% of the cases the transistor might have some problem that cannot be measured with a simple diode check.
3.1) If you don't have a BC154, the replacement model is BC416 (so says the internet). If you can't find BC416, you might try the BC161. BC161 should work fine for this purpose and since you fixed your preamp with that model you might even have some spare 161's available.
Good luck with testing! š
manfy
