So now for the next set of issues.
1. Stable voltage is now sitting at 40.8V iso 30V. Adjusting the trimmer has no effect whatsover and this is a new one.
2. My original problem. The RIGHT preamp channel (QII) is dead.
- electrolytics caps in that area have now been replaced
- it is not the cable (2 RCA to DIN) as it works fine with two other audio sources
- it is not the turntable either as that works well with my Technics amp
- tape and QI work fine with other audio sources, the dead right channel is only on QII.
- the pins on the QII din input are configured correctly
- there is continuity from the pins to the PCB
- there is 0.65V power supply to both 10u/64V caps
- doing left to right voltage voltage checks are giving approximately the same values left to right.
Anyone else every had this problem?
Thanks in advance.
Anton.
