Beolink Gateway BLGW vs. Beolink Converter NL/ML BLC NL/ML
Since they look the same, can you change their purpose by uploading firmware?
Here is the BLGW:
And here an older version of the BLC NL/ML:
And the latest Version of the BLC NL/ML:
I want to play with a BLGW to see how the Beosound 5 can be controlled via iPad App Beolink 2.
Instead of buying a used BLGW I could temporarily turn a spare BLC NL/ML into a BLGW - that is my idea behind the question...
Thanks for your Input!
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Any ideas / hints for me?
Ralf
Here is the BLGW:
Ralf
Ralf
both BLC are exactly the same. Just strip away the plastics strips on the BLC without AUX. You'll see the AUX connections are present.
Same on the other side of this BLC
Note: even the BLGW have them!
Thanks. I thought so About the BLCs, too.
But how about the Beolink Gateway?
It does look the same as well. So only a Software issue e.g. you Can Change a converter to a Gateway (and vice versa)?
Ralf
Ralf
Living Room: Beosystem 4, Beolab 7-6 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), no Subwoofer. Screen: Panasonic TX-P65STW60 Home Cinema: Beosystem 4, Beolab 7-2 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55 Home Office: Beovision 10-40 on STB Bracket wall mount masterlinked to Beosound 9000 MK3 on horizontal wall bracket driving Beolab 5000 Speakers Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all white, wall-mounted) In storage: Beolab 5000/Beomaster 5000 (1960s).
presumably the same! But how to get hold of the blgw software??
Addition: Not only present in the first generation BLC, but also in working order (PL, AUX, IR)
Hi Ralf, were you able to find a way to change the firmware? I found the latest firmware for the BLGW online, just need a way to upload it to the NL/ML converter! Rob.
You refer to the file 1.4.0.20048-signed.bin.zip?
I got this as well but never tried to upgrade the spare converter...
Bought a used MLGW but was not satified so I gave up on B&O home Automation for now.
Ralf
Hi Ralf, I am thinking of getting a used MLGW too, what is it you don't like about it? Regards, Rob.
is there already a solutions to upload the BLGW Firmware to a NL/ML Converter? I have one spare and would love to experiment with a BLGW.
