Beolink active + Beo4 + Arduino to control home lights...
Did you figure out the i2c communication from the eye?
Yes, this is very simple as it is based on a simple 8574 chipset. By the way, if is is for interest for some people, I recently hacked a BEOSOUND5 that was stuck, replaced the mainboard by an Arduino, and managed to decode all the wheel information (volume, selector, etc...)
I only have a problem with the IR detector with does not work well with the beomote library (for the moment)
I will couple the Arduino to a raspberry pi to have a multimedia unit  .
Would you mind sharing it?
This is a cool project!
I have a comparable use case in mind: would it be possible to use a B&O IR eye to generate IR signals that can control non-B&O gear?
