PART 2: Beoremote_Lookup_Table
//Bang&Olufsen Remote code table
//This table cross reference codes from the BEO4 and BEORemote One
//controllers, some codes are used differently in the two command sets,
//those differences are highlighted in the naming when needed (BEO4...,BEO1...)
//Command Set summary
static const int NUM_0 = 0x0;
static const int NUM_1 = 0x1;
static const int NUM_2 = 0x2;
static const int NUM_3 = 0x3;
static const int NUM_4 = 0x4;
static const int NUM_5 = 0x5;
static const int NUM_6 = 0x6;
static const int NUM_7 = 0x7;
static const int NUM_8 = 0x8;
static const int NUM_9 = 0x9;
static const int CMD_TV = 0x80;
static const int CMD_RADIO = 0x81;
static const int CMD_CD = 0x92;
static const int CMD_DVD = 0x86;
static const int CMD_LIGHT = 0x9B;
static const int CMD_SAT = 0x8A;
static const int CMD_VTAPE = 0x85;
static const int CMD_MYVIDEO = 0x87;
static const int CMD_MYPC = 0x8B;
static const int CMD_MYMUSIC = 0x91;
static const int CMD_TEXT = 0x88;
static const int CMD_GUIDE = 0x40;
static const int CMD_DTV = 0x8A;
static const int CMD_AUX = 0x83;
static const int CMD_NETRADIO = 0x93;
static const int CMD_NMUSIC = 0x94;
static const int CMD_CINEMA = 0x58;
static const int ACT_RECORD = 0x37;
static const int ACT_MENU = 0x5C;
static const int ACT_DOOR = 0xA8;
static const int ACT_STOP = 0x36;
static const int ACT_MUTE = 0x0D;
static const int ACT_SHUTDOWN = 0x0C;
static const int ACT_EXIT = 0x7F;
static const int ACT_VOL_UP = 0x60;
static const int ACT_VOL_DWN = 0x64;
static const int ACT_REWIND = 0x32;
static const int ACT_FORWARD = 0x34;
static const int ACT_PAUSE = 0x36;
static const int ACT_BACK = 0x14;
static const int ACT_INFO = 0x43;
static const int ACT_LIST = 0x58;
static const int BEO4_PAD_UP = 0x1E;
static const int BEO4_PAD_DWN = 0x1F;
static const int BEO4_PAD_LEFT = 0x32;
static const int BEO4_PAD_RIGHT = 0x34;
static const int BEO4_PAD_GO = 0x35;
static const int BEO1_PAD_UP = 0xCA;
static const int BEO1_PAD_DWN = 0xCB;
static const int BEO1_PAD_LEFT = 0xCC;
static const int BEO1_PAD_RIGHT = 0xCD;
static const int BEO1_PAD_GO = 0x13;
static const int BEO1_ACT_PGMUP = 0x1E;
static const int BEO1_ACT_PGMDWN = 0x1F;
static const int SPEC_GREEN = 0xD5;
static const int SPEC_YELLOW = 0xD4;
static const int SPEC_RED = 0xD9;
static const int SPEC_BLUE = 0xD8;
static const int ADD_BEOSOUND=0xA5;
static const int ADD_BEOSOUND2=0xAD;
static const int ADD_BEOSOUND3=0xB5;
static const int ADD_BEOSOUND4=0xBD;
static const int ADD_BEOSOUND5=0x25;
static const int ADD_BEOSOUND6=0x2D;
static const int ADD_BEOSOUND7=0x35;
static const int ADD_BEOSOUND8=0x3D;
static const int ADD_BEO4AUDIO=0x01;
static const int ADD_BEOVISION=0xA0;
