Beolink 1000 remote programing
Can anyone help me to program a beolink 1000 remote? I have not used this system for a long time, and I cannot get it to work. Only manually
I'm confused.  The Beolink 1000 is just a button remote with no screen or programming options.  What is it you are trying to do?
Dave.
Which system? Generally you would have the audio system in standby and then nester sound 1store on the remote
Your Beolink 1000 should not need programming as such. It should just work if you direct it at the Beomaster in question.
Maybe it's dead and need batteries or a new printboard. A dealer should be able to help you with a new board.
Otherwise push AV button to see for reaction will work afterwards.
If the thing you want to control is in option 0 then your remote will not work either.
To change option setting:
Push sound, 1, store and the main master should flash for ok. Then it should work.
