Beolab 7-1/2/6 failure states
Hi!
Do someone know about the way the failure system indicated by the LED is working?
Speakers connected?
IC boards connected?
Ground/Chassis connected?
All together? Or a more complex way to raise system failure state?
Thank you!
A little backgournd:
I need to run the speakers outside its original cabinet. The woofers were still inside and thus couldn't be connected to its PCBs. The LED went yellow when turned on, so i conlude the woofers are missing by the PCB.
Now i finally got the woofers out and could reconnect with its wires. Plugged in mains and PL, LED went to green, but no sound. So i still miss or ruined something.
The wiring looks good compared with diagram in service guide. The to bad there is no current on PCB 2-P4 or PCB 4-P10.
How to check PSU? :P
