Asking a quick question for anyone else who might have this system:
I've got the BL5's programmed in as a device. I activate them when I activate my preamp.
The default power on setting works, but default power off does not. I attempted to reprogram the power off function, but I ran into a problem. a) The Logitech remote has some kind of problem picking up either the signal or deciphering the code. It just keeps stating "could not recognize the signal, please try again". This was with both a Beo4 and a Beoremote One. b) Thinking it was a software issue, I created a new command (poweroff2) and tried to program that command. I still had recognition problems, but eventually, it actually worked and picked up a signal and programmed poweroff2. However, when I put poweroff2 into the power on/off settings (with a .5 second duration), it still didn't turn off the speakers.
For now I'm just using my beoremote one to turn off the speakers, but if anyone figured out this issue, let me know? I'd like to have just one remote control around if possible.
