Your list is more or less like mine, I have a handwritten list, but ended up with a kit (all axial) from Martin, my BL works good with the kit, but I would list which caps are really needed as axial and get the rest as radial, a lot easier to work with and easier to get within the values.
From Martin I got this conversion table:
4 uF = 4.7 uF
25 uF = 22 uF
50 uF = 47 uF
80 uF = 100 uF
160 uF = 220 uF
200 uF = 220 uF
400 uF = 470 uF
Where possible I would go for radials 105°C, Nichicon or Panasonic, the orinals are all 20% so keep within the margin or go one step up in uF and voltage. If I remember right, for the big ones, I went for Nichicon 105°C 2700 uF 100 V and 105°C 3300 uF 63 V
And as I told before change the "Black Drop" transistors with BC 550/560 B or C, (both low noice TRs) and make sure you get the polarity right, I spend some hours searching because or inverted polarity.
Come back with more, it is getting interesting, and remember we are checking on you 😁
Printing machine technician
Rock and Roll music
Collecting Vinyl
