Beolab 5000 Amplifier Mexico
Finally I have time to start on the BL/BM 5000 Amp and receiver. This is going to be a long thread, I have never worked on these items before, but I want them to come out working and looking as near to original as possible, where I will lean more to function than look if I have to compromise. I will however stray away from the original if better or more reliable components are available, this to get the best working and sounding equipment possible within my means, economical and knowledge. Along the way I will ask some stupid questions, where Martin will answer "we are here to help not to educate radio technicians" 😁, and others will tell me to do some research before asking questions, Normally in my threads I and some others members (no names) stray away from the core and have long discussions about something else, please keep to the matter at hand and if you want to stray away, post a link to another thread.  I will welcome all the help, remarks and good advises from all members, if questions are asked I will do my very best to answer them.
In this thread I will concentrate on the BL 5000, the BM 5000 will get a separate thread.
History: I bought the BL/BM privately from an E-bay member on May 4, 2015, and shipped from Wilmington MA to McAllen TX, where it arrived on May 8, 2015. I picked it up there on July 26 and brought it to Mexico city by car (1200 Km.), on the BM there is a sticker attached "Audiokrafters" with 2 addresses, one in Washington DC and one in College Park Maryland a short search didnt come up with info about it, so one wonders how it ended up near Boston MA.
First pic at home in Mexico
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
This should be fun Søren.  You can be sure that everyone will be supporting you on this. In the end you will have a nicely restored, classic system to enjoy.
John
The first help already there, Square4 will send to my son in Copenhagen 3 push buttons for the BL  and an antenna knob for my Beolit 505, amazing amazing
Square4 is a long time member we hardly ever see on the forum, but he is there watching, THANK YOU.
Retired
Rock and Roll music
Collecting Vinyl
At last! We are all in stand-by mode here Søren!
A good thing: all the sliders appear to be crystal clear, and so does the tuning meter. 🙂
And don't forget that Frede is never very far, and you do have the advantage to speak Danish.
I'm lucky enough to have met both Søren Mexico and Square4 in person and I can honestly say, that both
are true gentlemen in the best meaning of the word.
And Søren, knowing your skills and the way you take on new challenges, there's no doubt in my mind that
you will end up with one of the best and nicest Beolab 5000 systems ever.
If there's anything I can do to help, just say the word.
Thank you Martin for the kind words, the Square4 part is totally correct, but about me there are other opinions 🙂, but lets get serious.
The number, now this is a US version Series 80, figure that, the Danish versions goes 01 to 09 something, but Frede or Martin will know why.
This one has been checked and found OK by Karl Hansen
To check it I will have to open it, done by loosening 2 and removing 1 screw, red arrows, the outer screws are the 2 inner ones, loosen these only and pull back and up and the top cover comes off.
Well the 3rd screw was missing, some has been, or tried to get, in there
I did see some corrosion here and there on the outside
It didnt stop there the inside is worse, reminds me of the BM 4400 I made (Still my most used and still going strong)
That transformer housing makes me feel bad, I am glad I didnt connect the BL before opening.
Right in the middle of PCB No. 2 there are signs of a spill or something
I will split it up a little, i told you it will be a long thread
Retired
Rock and Roll music
Collecting Vinyl
Continuing
First PCB open, I like this construction, easy to get at
These blue caps change color when going bad, measurements will show at a later time.
The PCB below is dirty but apart from oxidation on the trimmers no visible failures
The other PCB open, again the color change on bad caps.
Here close up, and that also explains what I thought was something spilled, the yellow one blowing its head off.
And here the "spill" one, leaking all over the place
Even down to the big caps, can this also be the cause of all the corrosion ???
Dirt and corrosion mostly in the transformer side
To open the bottom cover
The leaking cap went all the way down to the bottom cover
The envelope long thought about, and a loose sticker, whereever it came from
And here it is, maybe only touched by one of my girlfriends hands until now, if you want copies just tell me
The front 2 Allen screws off (4 mm Allen key)
When off check for for 2 washers
Off, sliders OK, but yes a little yellow
Missing lettering even on the volume, wonder what hey purred on there
The push button front, pull off all the push buttons and unscrew the 2 supports
Off. For the power lamp there is a diffuser, a simple piece of tape
Dirt and some unknown fibers, wonder where they come from, the missing lettering sucks, I am thinking about metal engraving to solve that
These fibers I find mostly on the outside, I wonder if the BL was stored in a Sisal rope or in a marihuana factory, I somehow recon  these fibers
And thats it for today, tomorrow I will have to get at the transformer
Retired
Rock and Roll music
Collecting Vinyl
Good luck old friend! Wish I had a tweeter to contribute!
No need for a tweeter, because of you my M70s are doing good work several hours a day, even the BM 4400 at full power they handle without complaining
Retired
Rock and Roll music
Collecting Vinyl
Now Søren has finally found a culprit Rich: because of YOU he listens to his M70s every day! 😎
How about using that hammered paint you did the BG 1000 with for the transformer? Would it be possible to fabricate a new box? To get the transformer out of the old rusty one at all?
I remember that the seller did say it worked well... How could it? 😕
