Back to the thread, only post if you have help to offer,
I am going crazy here, I have been through all switches they all work as should, some of them a little slow to come down to 0.1-0.2 Ohms resistance but they all get there.
The only thing that works properly is the tape input (switch on/in), everything works volume, balance, filters, mono and speakers 1 and 2.
Any other input gives failures, connected a BG, stereo gives sound in right speaker, mono switchR on gives sound in both speakers, Mono R and L on gives sound in left speaker, Mono L on gives no sound in any speaker
The other inputs except tape the same. I check the inputs and wonder, Tuner and Aux is in my opinion input connections and they are pin 1 and 4, Line out is an output and that one is also pin 1 and 4.
Question: Do I have to make special cables for connections. Or is it another failure. ???
