I have a problem with my BeoLab 3500 :-(
The other day I had to unplug it for a while and since then it doesn't take any commands from my beo4 anymore. I tried two different remotes (beo4) and also made sure that they worked elsewhere. There is no problem with the remotes. The link connection is also working fine, since I can play music by using the hardware button the front: it plays as used to.
Now the question is: can this be a software issue or do you think it's a hardware thing? How can I fix it?
Cheers,
Johannes
