A friend of mine has asked me to fix his BL2000. He described the fault as an intermitent power problem and thought it was a loose wire in the mains connector.
I got the BL2000 earlier today and couldn't get any lights to show despite trying various power leads. I therefore stripped it down and checked a few internal voltages.
I found that the transformer primaries were getting the full 230V, but that the secondary is only showing 19.4VAC rather than the 30VAC listed in the service manual. Also the PCB1 dc voltage was only reading 4V, rather than 5 as required.
Do the transformers often go wrong - I couldn't see anything obviously wrong with the winding connections? Any help would be much appreciated!
