Hello
have you still gear as mine is broken ? Regards
Hello
Hello
I have the same part broken on my CDX-2.
Found the part on ebay and ordered it.Although the title does not list the CDX2, the description does.
Coen
Yes, I can supply the gearwheel. (I don;t sell on ebay).
Hello I need one for my beogram cd3300
how can de do ?
thanks
I need also the end contactor Well I don’t know the name in English This is the component connected.
Do you know where I can find it ?
Are you able to support me how to remove the yellow gear?
The white gear blocks the way and I don't know how to remove the white gear.
Are you able explain me how to remove the yellow wheel?
Hi Beobuddy
I have just joined Beoworld and browsing through the archive I came across your post from last year.
I am currently trying to rehabilitate my old Beogram CDX and discovered the lid drive gear is stripped and needs replacing.
So I would like to know if you are still in the business of 3D printing this gear and what would you charge for it. I am in Australia so you should also allow for slow overseas postage.
Thanks in advance
