Hello everyone,
My Beogram CD 6500 has developed a strange issue. As I remember correctly it used to work like this: when listening to CDs and switching to another source for example radio, Beogram used to go into pause and it still does, but after longer period of time, when still unused, it used to go to standby. Right now it stays in pause indefinitely, moreover when I listen to the radio and switch my BM 6500 off, the BG CD stays in pause! Pressing Control -> CD -> St. by on MCP doesn't do anything. I have to press CD, then CD starts playing and I can turn the whole system off either via MCP or directly via BM, BG etc. Also I've noticed that sometimes the stand-by indicator on the BG CD doesn't light up, nonetheless the BG CD continues to function as it should - the tray does open, pressing play will initiate playback, and then st. by indicator is back on!
The player has been fully recapped one year ago, including small reset caps near the ICs. I was especially careful not to cause any ESD damage to ICs. It is otherwise fully functional and reads every single CD I want to play.
Does anybody know what can cause this abnormal behaviour? ICs contain masked ROMs so I hope they're ok, as replacement won't be possible...
Thanks a lot!
Filip
