Beogram 8002 Repair
This Beogram 8002 was a recent find. I picked it up as a learning unit because one of my primary, everyday turntables is a Beogram 8002 I bought way back in 1983.  That original 8002 is still working well.  I had a B&O technician look at it about eight years ago and he made some adjustments.  That was before I took on this vintage audio hobby.  When this recent aquisition became available I decided the price was too good for me to pass up.
In the picture you can see the lid assembly is off.  The main spring and lid attachement came apart.  I am going to fix that first.
Electrically, this new 8002 powers on and the turntable starts spinning as soon as it is plugged in.  None of the pushbutton controls work.  So this could be a real troublesome repair.
Here is a picture of the re-attached lid/spring assembly.
Another picture of the re-attached lid.
Service position
01 and 02 modules from under the control panel
01 (PCB1 - Control Circuits and Power Supply) and 02 (PCB2 - Microcomputer) Modules removed.  With this Beogram 8002 starting up turning at 33 RPM when the unit is plugged in ... does that point to a problem with the microcomputer?
A mechanical question - The picture below shows the cover panel (the one that is under the tone arm when it is at rest).  The underside of the panel has a smaller metal panel that appeared to be glued to the cover panel.  That glue has become dry and crumbly.  In repairing that piece, do you scrape off all of the old adhesive and apply a new adhesive like epoxy or something less permanent like tacky glue?
The crumbly adhesive is also in small squares on the under side of the aluminum top plate.  What is the function of that adhesive and what should be used to replace it?
It is the remains of the foam double sided tape that was originally used to hold the parts together.
I had some success in repairing a TX using double sided carpet tape. It's about the same thickness as the original and has a very strong hold. You may want to try this too.
