Hi everyone again!
As part of putting my new B&O devices again in top working order, today I started working on the mechanical part of the Beogram 8000. I successfully cleaned and lubricated again the tonearm carriage (now it moves very quietly and without "effort"), but I have two main questions... I'm sure you will be able to help me.
1) My Beogram has a strange piece of some kind of hard scotch tape in this position:
http://www.flickr.com/photos/18028488@N03/7895786954/
http://www.flickr.com/photos/18028488@N03/7895786686/
It makes it a bit hard for the tonearm carriage to move freely when it gets to that place... They are basically crashing and I see no sense in that. Is this an original part, or is it there for unknown reasons, maybe a previous fix for something else (strange...)?
2) The service manual (page 5-1) says that the upper part of the control arm should be 19.5 mm far from the turntable platter. I regulated everything starting from this assumption, but now the stylus brush is way too high - I had to remove it in order not do damage the stylus. Should I measure the 19.5 mm from the black plastic part or from the aluminium part of the platter?
3) The service manual (page 5-1 again) says that the turntable platter should be 2 mm higher than the cover plate. Again... The aluminium or the black plastic part? I would say the black plastic part, the aluminium staying on the same level as the aluminium cover plate... But... Could you confirm?
Thanks for your help!
Marco
