Hi
I have the above that I am looking to swap for a decent turntable (non b&O) They are rosewood other than the speakers which are teak - physical condition of all of them is excellent (other than the speakers) - however not so good are the faults these are;
Beogram 4004
Has the speed fluctuation issue, I have bypassed the relay to switch between 33 and 45 so it runs at 33 but can have a replacement one if you wanted, installed new trimmers on the main board and changed the belt. none of this seems to have worked although it is better, it is either the caps or motor I think, bypassing the user trimmers on the top panel did not work either. Physically it is excellent though and comes with a cartridge. Tone arm and everything else works as it should - I have just reached the extent to which I can work on it.
Beomaster 2400-2 and Commander
Works fine and in excellent condition but needs some bulbs replacing - the commander only works on half side and Martin suggested a fix by replacing a couple of parts.
S60's
Work and sound great, woodwork at the bottom corner of one is chipped but could be restored
BC7700
Amplifier and radio work, condition is good, some of the segments in the display do not work, turntable needs a cartridge, belt and the counterweight is missing, cassette needs belts.
Ideally I was looking to swap or part exchange for a good quality turntable as that was my intention in getting the Beogram in the first place, I thought maybe this would appeal to someone who may want to do a swap or am open to offers so that I can put the money towards a new turntable
Half the equipment is in North London, the other half in Frinton (Essex) so can be collected from either place if you prefer.
