Beogram 4002 Parts
Dear all
Is there any way I can test the quality of the stylus? If I'm not wrong and if I need a new one I need to get the whole cartridge MC4000 right? What is quite expensive right?
What is the point of getting a used one? Is it worth the saving?
Plus, I need a 20v wired end terminal lamp that and can't find anywhere in the world!
Please help help help!.
Really appreciate your comments. Thanks a lot in advance.
Thank you so much Sonavor. That was most helpful and encoraging.
Wow, I will definitely have a look etype76. Thx so much
Hi Jacques,
Is Axel from one of the places below where it is not worth trying any more?
Soundsmith , Schallplattennadeln.de and Tonabnehmer
Thx
Where are you based?
