hi,
I have 1 beogram 4002 with the power supply / transformer death. I found one power supply / transformer beogram 4000, is that I can use? does it have to do something special?
thank you
Beogram 4002 changed Power supply
They have different part numbers - but they look very similar! What type of BG4002 do you have?
my Beogram 4002 type 5501, the problem is that on my Beogram it there's two blue wire coming out of the transformer but the transformer I found it there's over 6 coming out in dc: two black wire , 2 red and 2 yellow ...
Stéphane
They are not interchangeable.
But many people are looking for working BG4000 transformers so you can easily part with it again. 😂
I know that "strong forces" are currently working on a solution to the BG4000 transformer problem.
Contact fellow member Menahem, he knows someone that can re-wind B&O transformers.
Derek
thank's for your answers, I'll actually see a transformer rewind.... 🤒
regard's
Stéphane
Martin,
What's the BG4000 transformer "problem"?
Menahem
I actually have a working Beogram 4002 Type 5513 transformer laying around if you are interested 😕
hi Soren,
thank you for your offer but my Beogram 4002 is 5501 type ; it is AC powered while on your Beogram, the motor is DC powered.
It's a pity
Stephane
Hi Menahem
The power of my Beogram 4002 is dead, I have a power supply for Beogram 4000 (My Beogram 4002 Type 5501 is supplied with AC output transformer as Beogram 4000).
But I do not know what I should have voltage output power on my 4002 because the transformer is dead, I just do not measure ... On the plans, I found voltage but come after the diode bridges as they are low and I do not think it is good value.
I need the secondary voltage of my Beogram 4002 TYPE 5501 for adapt the transformer 4000.
thank you for your information
Stéphane
