Hi
sonavor,
Correct.
Perfect balance is unfortunately very close to whenthe tonearm base is too
close to the counterweight. Slightest move of the adjustment screw, and the arm
is stuck. Anyway...
Well,
current status is that error #5 is back again.
Same as in
my very first post here, I was about to adjust the tracking force using the
tracking force gauge. I pressed ON, tone arm moved to 30cm position, and lower.
Then I used > to move the tonearm back for the adjustment. It was possible
to start moving it back, but not stopping it. When pressing forward (>), it
just stopped for a split second, end then continue back home. And after that Error #5
seems to be permanent again.
In Dec 1
you suggested Electrically, measure the DC voltages around 1TR25 and see
what they are when the /Q0 is a logic
"0".
So now I did:
C: Varies
each time I press ON. I got 16V, 2V, 10V, 5V, 1.3V.
B: 0.6-0.7V
E: 0V
Per
