Hi!
I have a
Beogram 4000 that was damaged in shipment. It was well maintained prior
shipment. I initially posted here: link,
but got recommended by sonavor to start a thread here instead.
The [numbers] refers to the Service manual. More pictures and clips can be
added upon request.
Mechanical issues found (but now corrected):
a) The Slide was loose and tilted and the Detection arm was relocated towards the Tone arm (see picture IMG_3629.JPG). Login to view image
b) Pulley [124] came loose during transport and has likely been rattling around freely inside the Beogram. (in this Beogram replaced by a metal version, see picture IMG_3630.JPG). Login to view imageIt was found again under the Turntable [4]. The loose Pulley resulted in the free moving Slide.
c) The Slide threaded rod (Spindle [224]) was hanging loose-ish, also an effect of the loose Pulley.
d) One of the Slide Contact pins and its plastic holder (Switch E, SO - Switch off/Home position) were knocked off.
Functional issues found (please note that issue #5 is now permanent and overrules the other 4 issues):
1. Tone arm lowering even if no record is present. Intermittent problem. Happened both on 7" and 12" position. The detector arm bulb is lit up, but something is wrong in the sensor circuits.
2. Another intermittent problem: sometimes the detection arm function works when scanning an empty platter, but then when the Slide are reaching end position, the servo motor continues to push the Slide to the center. OFF has to be pressed to return.
3. The Slide stopped over the 12" position, then slowly moving towards the center, then returning back home. This occurred both with and without record. Don't know if this is a normal operation, but it happens intermittently.
4. When playing a record, the arm lowers, but after 1s the servomotor starts and the arm moves across the record for about 0.5-1cm (my poor Pink Floyd album).
5. After that I started (in pure frustration) to adjust mechanical bits and pieces according to the service manual. When I came to the step of Tracking force adjustment, I started ON, then pressed Reverse (>) to move the tone arm away from the platter. When I did this, the Slide decided to return to home position. I pressed ON again to repeat the procedure, but the Slide moved ~1 cm, then returning home again (see
