Hi sonavor,
Regarding
the logics:
I have now
read the document you recommended, BG4000 Training Notes manual. I will leave
3IC1 be for now. I focused on section 3-25 (3IC0). I measured the voltage of pins,
but I'm a bit hesitant to draw any conclusions anymore, so I'll just present
the results below. As you also pointed out the Fault-finding diagram 5-4 in the
Service Manual, I'll present the measurements for these signals as well.
IC0
Pin Function Voltage (V)
1/2 NAND (/Q0) 0.06
5 SI 5.85
7 +6V 5.85
8/9 NAND 5.75
10 ES 1.93 (a
bit lower this time, 2.6V last time I measured)
11 OFF 1.93 (a
12 /Q1 5.57
13 Input fr.3IC9 2.32
IC1
5 WO 5.8
13 "Is SI missing" 0.77
IC7
2 DR 5.87
5 BL 5.88
The
detector arm light = On
Regarding
SI:
I studied
the Start Impulse (section 3-11 in the Training Notes manual). I don't have an oscilloscope at hand, so I'm
not quite sure I can observe the 10ms pulse we are talking about here. I can
buy one if needed. Can transistor 1TR20, that generates the SI, give some hints?
Any ideas what to look for in that case?
Regarding
what happened during transport:
As far as I
was told, the Beogram was in good shape prior shipment. Please note though: issue
#5 was not present when I received the Beogram. That error appeared
a couple of days later. The "only" failures the first week after arrival was issue #1 -> #4:
1. Tone arm lowering even if no record
is present. Intermittent problem. Happened both on 7" and 12"
position. The detector arm bulb is lit up, but something is wrong in the sensor
circuits.
2. Another intermittent problem: sometimes
the detection arm function works when scanning an empty platter, but then when
the Slide are reaching end position, the servo motor continues to push the Slide
to the center. OFF has to be pressed to return.
3. The Slide stopped over the 12"
position, then slowly moving towards the center, then returning back home. This
occurred both with and without record. Don't know if this is a normal operation,
but it happens intermittently.
4. When playing a record, the arm
lowers, but after 1s the servomotor starts and the arm moves across (and
scratches) the record for about 0.5-1cm.
I'll try to
describe (and remember) exactly what was going on when #5 first appeared:
I was moving
the Slide from Position [ D ], first groove of the record, slowly to the right
pressing ">" with several, short intervals. (Purpose: to get the stylus over
the aluminum plate for tone arm weight check). I pressed ">" a few times,
and then the issue #5 appeared, causing the Beogram to switch off. After that I
removed the Slide Contact Spring assembly to reach the Slide Contacts. I
pressed the contact pins, probably from the right to the left, and then I might
have smelled burned electronics.
Per
