Beogram 2000 524x query
Hi can I use another type of motor for this deck as I'm struggling to find one. Thanks Phil..
Beogram 1203, 1202 etc.
What is wrong with the motor? Are you sure it cannot be repaired?
Ben
I've found a motor from a 1203 the wiring is different, do you know which wire goes where please?  Thanks Phil..
All these motors will need servicing by now.
Replacing it with another won't provide a lasting solution unless the replacement has been serviced.
The best solution would be to have the original motor serviced.
