Hello soren and Martin,
Thank you both for your reply. Soren, shift lever and clutch are working fine, I have tested yesterday.
It feels more like Martins suggestion I'll have to check this later this week.
Martin, just to make sure, I have circkled the nylon wheel in the picture below, is this the rod you mentioned ?
Login to view image
