Beogram 1000 Questions
Beautiful deck !
Take off the bottom plate (two screws) and look inside. Many decks have an extra serial number label inside.
Does it work correctly Ben? What's the lid like? Do you have the SP6/7?
I think you'll be pleased. I love mine which probably has the same round motor. It looks nothing really special - a bit diminutive even - but it sounds really good.
Here the serial number of the one I just bought (also grey model), yours look better Ben.
Printing machine technician
Rock and Roll music
Collecting Vinyl
As all the items I buy on Ebay US, also this one is shipped to my family in McAllen TX, it will then stay there in the box until I can pick it up. this always take some time (up to 6 month) and I cant check the items upon arrival, so I can never return or open a dispute over anything i bought this way. But until now I was lucky, only a BG RX did not come as described, I had to use that one as a donor unit.
Rock and Roll music
Collecting Vinyl
Also, thanks Martin, the serial number was inside as you suggested. Does anyone else keep a record of their serial numbers or is that just me π
The lid is in good shape Jacques in answer to your earlier question, but does have a small crack on the back corner. Hopefully it will polish up either way,
Ben
Luckily it also has the optional pre-amp so it works well with my Beomaster 900M and type-B speakers.
Ben
A RIAA module was also available for the BM900.
It replaces the Phono input DIN socket.
I've also seen the Beogram 1000 RIAA built in to a Beomaster 900:
Login to view image
Where there's will....
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
