BEOCORDS 6/8XXXX
A couple of years ago I got a BC 8002 HX-Pro, for a kiss and a bottle of wine, along with the message that it did not do what the makers had in mind when developping this cassette deck.
In seach of donor applliances I acquired 4 more items, also with problems.
By exchanging and swapping mechanisms as well as buying new belts  I managed to get one running properly: the BC6000 HX-PRO.
This one also did something positive with the mechanism from the BC8002 HX-PRO.
The BC8000 provides some positive response with mechanisms from the BC8002 HX-PRO and from the BC8002.
All this summarized in attached picture of a matrix, which I hope is selfexplanatory.
If somebody feels the urge to take a look and is willing to help me, than is this the question:
Do not pay attention to items 1, 2 and 5,
I would like to know if the missing activity of decks 3 and 4 is due to mechanical faults (idler wheels, lubrication) or weak electronics somewhere; I have tested with all combinations of belts.
Aad
Hi Aad,
Whenever I have restored a Beocord 8004 or Beocord 9000 I always start with disassembly and cleaning of the mechanical cassette assembly. While it is apart I replace the rubber wheels and the two belts which I always get from Martin at
Hi Sonavor (nice name),
Thank you for your "encouraging" reaction, but such a diassembling job is for me far from a piece of cake. I'd better stick to changing belts and replacing electronic components: all those tiny screws, bolts and springs make me decide to stay far from such an operation, although I am confident that I will be able to loosen*) all those parts, but putting all those things back later on will give me to many sleepless nights.
*) I did this once and I what was left among other bits was  this wheel.
Is this the one that you mention in the above reply?
If so I can send it over to you: drop me a pm and it will be yours.
Aad
Hi Aad,
That isn't what I meant by the thrust roller. The thrust roller looks like this -
Hi Sonavor,
Also this one is among my spares.
Are you still interested? Then I can send it to you,( free of charge)
Regards<
Aad
