Hi all,
I finally started work on my Beocord 8004 which had been sitting on a shelf for three years. It is a companion to the Beomaster 8000 I restored. I never even tried it before. There are however two problems.
Left channel missing
There is no audio coming off the left channel. Using my tracer I can see that the head itself is outputting audio. It just dissapears on the main board, almost immediately. I have a service manual but am scratching my head at this currently as there is absolutely no context for the schemas. I am suspecting the little relay as this appears to be the first in the chain, but I am absolutely not sure.
LED segments missing
It seems that I need to redo the LED boards. Luckily I know how to solder SMD components with a microscope. But I am wondering if anyone can share which LEDS they have used (make and type or perhaps an order number from Mouser)?
Many thanks for your help!
BB
