Hello to all community,
I have been working in a Beocord 7000 that refuses to play. The unit looks like in perfect condition, all belts have been changed and in fact moves in FF and Rewind without problem.
The issue starts when the play is press, the capstan try to engage but changes from one side to other because the tape seems stucked.
It would be possible to FF and Rewind if the black wheels are blocked or partially blocked because of the famous small white pin? I did what is advised somewhere in the forum but I'm unsure if the thickness got has been enough
Any idea where to look for?
Thank you very much
