Beocord 4500 - no sound
Hi there.
My Beocord 4500 is mechanically working fine, but it doesn´t deliver any sound. The VU-meter though lights up all the way, when pressing play, and keeps on shining steady, even without any tape loaded.
Anyone with an idea of what is wrong?
Regards
/Sven
Missing 8Vref voltage.
Usually one or both of the 470uF/10V caps C217 / C417 has shorted.
Thanks Martin. I´ll replace them.
/Sven
Hi again.
How come the two aren´t the same on the PCB as they seem to be in the service manual? I don´t have the component list, only the scheme.
/Sven
Probably a typo on the board.
C417 is the correct one.
That did the trick. C417 was shorted. Now it´s working fine.
Great thanks Martin. You´re the best!
/Sven
