Hi all, newbie here that needs a bit of help.
I've recently re-discovered my father's BeoSystem 3300 after it being in storage in his loft for many years. 🙂
The Beogram is, unfortunately, completely scuppered (water and physical damage) 😠 but the rest is in superb physical condition and the Beomaster is working flawlessly. 😁
Last week I purchased a Thakker belt kit for the beocord, as I could hear the motor running but got no response to pressing any of the buttons except it would stop automatically.
Upon disassembly I found the main drive belt very stretched and it had completely slipped off the drive pulley.
So I have re fitted all of the belts, and today I decided to test it now that I had a blank cassette. The Fast forward and rewind are working fine but if I try to play or record the unit just goes to 'stop' after about a second or so. The heads are moving into and out of the tape as they should.
Is there some clutch/belt tension adjustment somewhere that I am missing? 😮
Any help would be appreciated as I'd really like to keep these units working as a tribute to my dad.
Thanks!
Ben.
