Tamtapir animated me to start on my BC 2000, so here goes. I am not as brave as D""ck, I have had some bad experiences with connecting used devices without checking the inside first, furthermore the main cable looked very bad with the insulation coming off in places, and as it is a little special, I dont have another to connect the BC.
First thing I took off the top covers, knobs come off easily, some of them has a screw, the other ones are just pull off.
Not too much dirt in there
Then the bottom cover, found the drawing, a loose label and some old foam inside
I could now see the PCBs and the way they did it then, simple but effective
Now look at the PCB connections, after more than 50 years ( maybe 60, I´m not sure about the build year), they are dirty, but as I see it, still with connection
Here a PCB out, as you see connections are there, but all around dirty.
Now I got a bit ahead of myself, wanted to see what Deoxit could really do, soaked the PCB connections with Deoxit, waited 5 min. and cleaned 2 tracks with a cotton stick, nice and clean without abrasives. That will also happen to your switches when you clean them this way.
Here the cotton stick, after cleaning one track.
All clean after 15 min. soaking
I now numbered all the PCBs as I´m going to treat all of them the same way. Then I took off the wood frame, 4 nuts and 2 screws from below. Here the tone heads, dirty but not worn. Red arrow is a tape guide, it had a kind of plastic cover (plastic tube), that one came off in 1000 pieces when i touched it just a little.
Here the erase head, not worn, but dirty. one guide, arrow, very dirty, but not worn, I found another one worn, amazing what a tape can do to chromed steel, I will grin/polish that one, hoping its only the chrome, and not through to steel.
Here one of the PCBs, they all look good, no heat coloration, and the caps looks good too.
All the belts are loose, the one for the counter broken, I hope Martin has a set of belts, if not, I have to shorten and glue or invent something, there is also a problem with felt guides and a felt clutch for play, but after cleaning it all I will come back with more. Its now 02:00 am, going to bed. Sweet dreams to all of you.
Printing machine technician
Rock and Roll music
Collecting Vinyl
