Hi!
Basically there is no output from either of my BC2000s I have finally got around to tinkering with. Where should I start the process of finding the issue?
BC2000 #1 - New belts and motor from Dillen. Tape FF, RW, Stop and Play all move the tape as expected. No sound when I play tapes (tried through BM3000 and BC5000). Output level lights to 0db
BC2000 #2 - Switched out tape deck with repaired unit from BC2000 #1. No sound from this one either. Output level lights to 4db
Could the 'no sound' be due to a faulty tape deck, or is there some thing wrong somewhere else in both BC2000s? If the former I will switch over the new motor and belts to BC2000 #2's tape deck. If the latter I am a bit lacking in knowledge😳
Thanks for any advice.
