I plan my new house sound system around a beocenter 9500 rebuild with an ipod inside
Then, because my living room is quite big I want 4 HP.
I try that:
I plug two HP on the standard passive of the BC9500 and  plug one  MCL2P on one of the power link 1 for the two other HP
Alas each time I put the BC9500, I here a big crack as soon as the MCL2P receive power then it's work normally.
is there a way to avoid the crack ?
is it better to plug the 4 hp in parallele, 2 by 2 ? (I have only passive HP like P45, CX50, CX100....
(just for info there will be above that a 4 rooms MCL linkage with two MCL 2A and 2 MCL2AV+MCL2P)
thanks for your advise.
Francois (France)
I
