I picked up a Beocenter 9300 that was for sale locally back in June. The CD player didn't work and the glass panels were loose (they were missing all of the trim pieces except for the two that bolt to the frame).
After adjusting the CD player and finding some replacement panel trim pieces I have the unit working again. The only problem is the remote control doesn't work. I have two Beolink 1000 remotes that work fine with my Beomaster 5500. Nothing happens when I try them with the BC 9300 though.
I pulled the remote control receiver board but I'm not sure if I should open it up any further. The connections look fine. Where is the best place to start on this type of problem?
-sonavor
