Things are moving right along with the BeoCenter 7000 t1803 that I acquired recently. Martin has the tapedeck belts on the way and I got the tonearm adjusted so that it drops confidently into the start zone, no longer falling off the record half the time.
Poking around here, I saw numerous questions about the aluminum door over the control panel but no one asked about the plastic cover over the turntable. The cover on mine opens nicely but won't stay up. Hold it or drop it. I presume I'm not the only person lacking a third hand to hold the thing up while pressing the "turn" button and applying the record cleaner to the disc. Shouldn't the lid stay open?
My investigation has found two wire springs that don't seem to be doing their job. They are to each side of the lid, right and left. Should there be a third spring, in the middle? Checking the service manual, I'm unsure whether there is a hinge piece, similar to what the control panel door has.
Am I the only one with a sagging door?
Second question - I noticed question from someone who bought a type 1801 which he brought with him to the U.S., and now needs to change transform to operate on 110volt AC. If that can be done, how's this? My type 1803 came with an FM-only radio. Would it be possible to swap my FM only with the AM/FM/LW radio from a type 1801? I would enjoy that. I don't expect that would be possible.
Thanks for your advice.
JackM
