I know this has been discussed in other threads but i don't really recognize the symptoms as described by others.
I bought this unit for a reasonable price on an auction. I was informed that it had been dropped on the floor and no function guarantee was given. Anyhow i thought I'd give it a try. After receiving the unit I could see some external damage. One door was damaged and also the plastic case at a bottom corner. Tested the unit to find that doors where functioning but where not opening or closing fully. Radio was functioning flawless but the CD did't react. Removed the doors and back cover, doing that I found the most of the screws where missing. Open i found among other things the CD servo PCB loose and with the ribbon cables disconnected.
Reattached cables and reassembled CD unit. Now when testing the CD it spins for 1 second then stops. Don't read CD at all.
Putting the unit in test mode it looks as the laser is working, focus motor is working. laser motor working but when trying to start CD motor nothing happens.
CD unit is the newer CDM12 from 1999.
What is the most likely fault? The SMD caps on the servo board? If yes, all of them or any special one?.
Damaged door
Login to view image
Removing doors Login to view image
Straighten snap in bracket Login to view image
Corner damaged Login to view image
PCB inside damaged and "repaired" Login to view image
Servo board was unmounted, completely loose Login to view image
Ribbon cables unattached Login to view image
Bad caps? Login to view image
Reassembled for test Login to view image
