Beocenter 1800 - transformer runs very hot
Hi there!
I just received a Beoventer 1800 bought "un-tested" and started "testing" it :) Like most untested items, it needs repairs.
Plugged it, FM runs fine but I started smelling like something is burning after 30 seconds, so I turned it of. Took the top off and noticed the transformer was very very hot (hard to touch after only about 30 seconds running).
The smell also seems to come from that area. I am afraid of keeping it on further time because something might catch fire, but my question is:
How hot can a transformer run on these old receivers? What could I try to check first?
All help is welcome, many thanks!
Check the idle current settings.
But only power up very briefly! Only just enough to take one reading at a time.
I noticed this:
link
Could the transformer be physically damaged?
I still do not have the service manual, where could I test voltages?
I really would.love to repair this amp...
Yes, that transformer needs replacing.
Perhaps the record deck stood on it. It can happen if you're not careful when (dis-)mounting it.
Don't power the Beocenter up again before it has been replaced.
I do not know if it got loose on the delivery, but the transformer had lost the bolts that hold it to the chassis and came running on the record deck.
Now I really do not know where will I find a replacement :( not many B&O here in Portugal...
I do not know if it got loose on the delivery, but the transformer had lost the bolts that hold it to the chassis and came rubbing on the record deck.
Beoparts is always a good place to ask for parts for vintage B&O audio products. 👍
I'm sure I can find one in the dungeons.
Ok.. I would be pretty much interested!!!
