let me present you to the extension of the Beosound 1 PIN code protection system:
The BeoCat BeoSecure1! Superb speaker protection system.
Login to view image
Description:
Manufactured: 2003 - today
Design: By nature
Colours: White, brown, black, and some rose
Excerpt from the upcoming BeoCat catalog:
"BeoCat BeoSecure1 is a maximum expression, protecting your speakers. Efficient and elegant, fun to pla(y)ce around."
It is a tough construction, solid and is capable of multi speaker protection. The alarm signal does not need to be programmed, it is set by default. With its innovative two-teeth-first-bite-after-warning security concept it is a safe and well designed system for every Bang & Olufsen speaker owner. We recommend to use it with the Beolink wireless, the playmaker or in-wall wiring, so that the cables might not be interfered by the protection system. Sometimes the two-teeth-first-bite-after-warning security concept gets in a testing mode and will use the cables for testing material.
Example for multi speaker capability:
Login to view image
It may also serve as a sound calibration set-up, though this is an optional feature. If the sound settings are too much to bear, the alarm will go off and you know itยดs time to adjust.
Specifications:
Type: Maincoone
Voltage: High
Consumption: Usually too much
Tuner and sound system: Built-in
Power amplifier: Built-in
Frequency range: Appr. 400 - 40000 Hz (I really have no clue ๐)
80 dB Mono
Plays: Purring, growling, meowing, always clear and transparent
Haptic: Basically fluffy
Dimensions: Varying, depending on fur status
Weight: Around 8,5 kg
Related product:
BeoCat Gram1
Kind regards,
Rolf
