Hi all, I'm new here.
Became a vintage B&O lover a year ago when I got a Beogram 4004 my uncle bought at a garage sale for €1. Repaired its mechanics and hooked it up. Delighted by its ideosyncracy both inside and out. Completed the Jacob Jensen set with a Beomaster 1900 and a set Beovox S45 speakers.
Everything was fine until I decided to repair the bass slider which didn't work but didn't bother me. Unsoldered and glued all three sliders as per instructions found here. But now I had this nasty, difficult to pinpoint problem of the 1900 falling back to standby after the relay clicks whrn touching a selector button. I thought I had introduced a short out in one of the sliders and indeed found one caused by too much solder on two adjacent contacts. Corrected that. Still only standby.
I'm tearing my hair out now because I'm kicked in the butt by the proverb: if it ain't broke, don't fix it. I was more than happy without the functioning bass slider.
To make a long story short...the 1900 is now completely taken apart and waiting for caps replacement. Many of the red ones have yellow crust. (Will contact you about that, Martin)
My problem is that even if I replace these parts there is no guarantee that the 1900 will work again. I have no electronics skills or knowledge but I can deliver a tidy soldering job. And I can use a multimeter if told where to put it and what to check. But that's about where my possibilities to repair the 1900 end.
Do you guys think I'm up to the task of getting my 1900 back to life again or should I let go?
Thanks, Michel
