Hello
So I got my first B&O products today, a pair of Beolab 5000 active speakers. When I got home I set the selector switches to N and A and connected my phone to the line in connectors with a standard minijack to rca cable, just to verify that they work.
Sadly, one of them did not play. It seems to power up, showing the red status LED in the front, but no sound. I connected the seller and it turns out he never used the line in connections himself, but he had used both the power link and the speaker link connections. I'm getting a DIN speaker plug connector tomorrow to see if it's hopefully only the line in that's dead, but now I have some questions:
- Is this a common issue with simple fix? (he asked hopefully)
- From the manual I see that the sockets are rated:
- Power Link: 1 V/ 100kOhm
- Line In: 1 V / 33kOhm
- Speaker link slectable: 11.3 - 16 - 22 V / >47kOhm .
- I'm not sure how to interpret this, does it state the expected/suitable signal voltage and the input impedance...?
- Is it advisable to use the speaker link or power link sockets with a generic audio source? Which is better suited?
Hoping for some answers, for some or all questions above :)
Br
Marius
