Beloab 150 / Penta Upgrades
Hi all 🙂
I've decided to carry out some work on my ageing Beloab 150 amps / Pentas. They were originally Beovox Penta Mk1's to which I later added Beloab 150's when they turned up.
Anyway they have given good service over the years - and they are currently running cool. I feel though they are of an age where I should now carry out preventative work by way of replacing some components - and upgrade as I go. I'm on a budget so I intend doing the amps first - then possibly the Xovers at a later date.
First the electrolytics which I will replace with 105°C rated components. I wonder if anyone could recommend what electrolytic manufacturer / series I should go with - Panasonic / Vishay / Nichicon ?
I understand most of these are not in the signal path - but some of the caps are. Which ones are in the signal path and what should I replace them with? WIMA MKS2?
I will also replace the 10,000uF caps. There seem to be loads of Elna & Nippon caps on eBay, but I've read a lot about them being fakes 🙁
I wonder if these too are fakes:
I've attempted this upgrade, replaced C1, C2, C5, IC2.  Also R65, R66, R73 because they looked like they got hot.  Plus the caps in the power supply.  Now the amps will turn on, put I get zero output...not even hiss.
Suggestions on where to look?
Can anyone help with my questions 🙂
In the meantime I've ordered replacement foams for the midranges from Good HiFi. Mine are all still intact - but I daren't touch them 😐
I read too on the archived forum about a mod to get rid of the 'pop' on power up - but the link to the mod doesn't seem to work:
/forum/beogram/beogram-rx2-thumping-noise
Thanks 🙂
/forum/general-discussion-and-questions/beoplay-a2-just-released#post-2026433
Don't! Audiofriends has the right ones!
Oh 🙁
It's a bit late as i've already paid for them...
Are they completely wrong for the drivers? Should I ask for a refund?
I can confirm this!
Oh dear
There's not much I can do now - unless I ask for a refund if they haven't already beens sent.
I will ask
Even then, I wouldn't doubt investing in another set of foamsurrounds.
You will have the opportunity to compare the surrounds. You will notice the difference!
Again, I'm repeating myself, do not use the Good Hifi version. Among the more then hundred drivers I've done so far, there where several with the wrong surrounds fitted. They became loose around the chassis where the coil-wiring goes in. Or were simply bad placed caused by the wrong dimensions.
And order some speakerglue with it. You will get glue which stays elastic. Don't use PVA as I've seen which gets hard.
