Behringer UCA202 problem
i have a little problem with my BS5/BM5. my UCA202 doesn't work anymore..
a couple of days ago I entered in Service Menu to install a ASIO Driver because i get a very bad latency. I searched on internet and i found out that this driver would have probably solved the problem. When I installed it I restarted my BM5 and when it was on again i tried A.AUX but no signal. From that moment I tryed every possible thing.. I tried ASIO4ALL, I tried to uninstall this driver and let the system install the default one but no way, it doesn't work. I think that the driver installed was a particular one... does anyone has any idea of how to solve this?
thanks
Latency between what?
between for eg. my tv (non-B&O) connected via RCA to the Behringer. I have a latency of.. about 1 o more seconds or even if i connect my phone for example.. or anything there is this latency. but I can keep it is not a problem but now the problem is that isn't working AT ALL.....
Normally, in windows, if you install a new asio driver such as asio4all you need to go to the audio section of the control panel and select it as the default driver for audio playback, however I'm not sure how this works in windows embedded
