Hi Sonavor
The Analogique service was in August 2016, because the arm didn't
move (it was a broken belt), and here is what was performed:
Replaced belts
Replaced lamp(s) and/or LED(s)
Replaced capacitor(s)
Traced located and repaired electronic problem(s)
Reconditioned and lube bearings/carriage/cam
Cleaned and lubricated as necessary
Tested and ran
I have owned the turntable since around 1990. The last service
before 2016 was in 1997! At that time, Technetron in NYC did:
Replaced belt drive
Replaced arm belt
tip 141 transistor x2
tip 146 transistor x2
BC 156 (?) transistor
10 MF 16V cap (?)
Relay
The items with (?) are due to unclear handwriting. But perhaps
this gives you an idea of some upgrades that may have happened.
I took all the platters off and can see what is a clear problem:
Sometimes the arm moves all the way along the path. Sometimes it
gets stuck part way. Sometimes it gets stuck at the very end of
the play or before returning to full rest.
When this happens, the pulley and belt for the arm is still
spinning BUT the gold threaded shaft which turns with the pulley
stops turning. This is when the squeakiing sound happens.
If I give it a nudge the shaft will begin turning again and the
arm continues to move.
The belt on the arm pulley is new and appears to be tight. The
pulley has two screws to the left of it which feel tight to me.
The pulley also has a small hole on its right side, near the end
of the shaft. There is nothing in this hole. Is that correct or
should it have a small screw there.
When it gets stuck at what would be the end of the LP, the only
thing that makes it return is to hit the stop button.The pulley seems to have some lateral movement on the shaft (left
to right). When the pulley is hard left on the shaft, a very small
amount of the shaft protrudes on the right. During the course of
the arm moving, when it gets stuck (at this point the shaft stops
spinning) the pulley seems to have shifted slightly to the right
and there is no longer any shaft protruding. If I push the pulley
to the left, the shaft and the arm begins to move again.
FYI, it had been suggested to lube the 4002 as a first try at
fixing it. The threaded pulley shaft had some grease on it. As I
didn't have grease, I used "Zoom Spout Oiler" Highest Quality
Turbine Oil, paraffin based non-gumming (the same oil I used on
the other lube points). Now there is really no grease on the
shaft, only that oil. However, the arm was already getting stuck
before I applied the oil. What type of grease should be on the shaft
(which can be easily obtained)?
I took photos of all of these things but I don't know if they tell
you much. I can try to upload them if they help you.
Thank you
Brian
