Can some please tell me how I can get the ipod to work the the Avant 32 (VCR). I have connected the audio into the top sockets (behind the clock) but I can't seem to configure the input from the setup menu.
Many Thanks
Steve
Many Thanks
Steve
Hi Steve
You've connected it in the right place. Now all you need to do is select 'Camcorder' on you Beo4 remote control and it should work fine.
If you don't have 'Camcorder' in the list on your remote, you can simply add it by pressing the power button (red dot) and 'list' button together. The Beo4 will then display 'Add?' on its display. You then need to hit 'Go' then search throgh all the options until you find 'Camcorder'
Good Luck!
Brill, now sorted.
Pity that it doesn't kill the picture to the tube though when not seeing a video signal.
Cheers
Steve
Surely, it can't be the Avant so it must be the iPod that caused the choice of the vintage forum for this post. 😛
