Hello Beoworld!
I have a Beosystem AV9000 from 1995 that I really like and It has been working without a problem for many years. But now it's started to turn itself off every 5-10 minutes. It just dies, leaving the curtains open. When I try to start it again it remains operational for another 5 minutes and then it dies again. I checked the error code and it says last error was B6 (which means nothing to me). But I suspected that the cause may be the power supply, so I replaced it with one from an older AV9000 i had.
But the problem is still there, even with the new power supply. I also checked the old power supply for bad soldering and burned out components and I couldn't find anything that looked bad.
Any suggestions what I should try next? I'd really like to fix it, since it (in my opinion) is the best CRT television ever made! Thanks!
