Nice job, I did onetime White/White 60s with 3M sprayglu, but it had difficulties to stay on. Got to check this Bison
That's why the fabrick must be as thin as possible!
Yes, that answered my question. Now for a new one - where do you get your fabric? I want to make sure I get the right thickness.Thanks "DMacri", I guess you alreay read the answer on Sonavors reply? Good luck doing yours Don't use to thick fabric for the cloth....
This is where I get my cloth on
Yes, it was. More exercises then...
very good job as always! Those RL's deserve a new life. Clever to use double sided tape! Emboss the B&O text is hard to do isn't ?
I like those DIY pictures it will help. I wish we could place these DIY tuts in a separate Item on this forum.
Hi!
Truly inspiring pics!
In the picasa album you are using a green tape which I assume is s foam tape? Is it the same used for BC glass panels? Where do you buy it?
Best regards,
Mikael
They can be placed in the Wiki's but someone has to do it๐
Hi!
Best regards,
Mikael
Yes it is but I'm not using this tape for glasspanels, much to thick...
Why are you ๐ Soren?
Thanks for uploading these pics Leslie!
I have the middle sized ones in black though. I want to recloth them in light grey or white.
You did a great job and like you, I was already aware of the bison sprayglue which is perfect to use for these kind of projects. I did them once, but wasn't satisfied with the fabric, this looks much better.
Register to access the forums, reference material, and exclusive member benefits โ including our monthly prize draw.
