As promised RL140, RL2000 and RL35 reclothing
looks nice Leslie!! good work!
My first thought was: how is the "bang & olufsen" text on the fret made... now I know, and how it is reclothed too π
which size of a RL speaker is equal or better sound wise compared to a CX100?
I guess all of them? I don't know to be honest, but I will compare them with my CX100's cause I have them all. Will let you know..
Great job on them, Leslie. I think I'll have a go at my RL140s now. What kind or double stick tape are you using?
Get the right one, I used a double tape, it was promised to stick on everything for years and came off after one week.
Printing machine technician
Rock and Roll music
Collecting Vinyl
Beautiful work as usual Leslie. I appreciate the detailed pictures. I too have a few questions though.
1. What brand of double-sided tape?
2. It appears that you brushed some sort of glue on and around the Bang & Olufsen logo first (makes sense - I sprayed on some 3M sticky glue on my first RL140 job). What kind of glue do you use for that?
3. In your finish steps, what is it that you are brushing on to the plastic frame?
Thanks,
sonavor
Thanks Sonavor!
1) link, use Ebay.de to get them cheap. Don't buy them at Conrad, far to expensive!
3)
Thanks "DMacri", I guess you alreay read the answer on Sonavors reply? Good luck doing yours π€
Don't use to thick fabric for the cloth....
Leslie, Nice job and great photo sequence .
Nice job, I did onetime White/White 60s with 3M sprayglu, but it had difficulties to stay on. Got to check this Bison
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
