Something I predicted just happened:
Article: "B&O Enables direct IP Control... no need for Beolink Gateway for NL products"
Do you see it available as a resource yet?It refers to this online service ; https://ifttt.com/ Beoworld app with direct photo upload and emoticons. Other apps: The Story Mouse . Grignan guide .
I reached out to a contact of mine last night in the company. He indicated we'll likely see
an update forthwith.
The IFTTT is not something I was familiar with but seems like it could be a nice advance
in the process. I.E. > notify me when my wife gets home? and he also says there's some way
to geo locate with the BLGW so that when your phone is within one kM of your BLGW you can trigger
a "Home" scene to come on. . .
I'm going to look in to the geo-location services this weekend. Seems interesting
Hi there
luckiky this does not bother me.
i don't want to control my system from a horrid cheap plastic remote I tried that and moved back.
I want to be able to control other devices from B&o using my lovely beo4.
im site this will open up loads of possibilities
I think this might be possible to pass LIGHT and CONTROL commands to the home automation in the same way, but without the need for the gateway. After all, NL is Ethernet based, if a Home Automation has got an Ethernet connection, why having a gateway.
I have a BL gateway, but all my setup is ML. If someone is fully NL, maybe they could do without the gateway.
